RCU Forums - View Single Post - I have an odd question ?
Old 01-27-2002 | 06:18 AM
tamjets
Default I have an odd question ?
[QUOTE]Originally posted by wiwanczyk
[B]vario makes a special gyro for 4 pont ccpm swashplates. basically the gyro controlls 4 servos to move the swashplate up and down and cyclic controll .... i can see one of these being used to connect to the ECUs, (all 4, just like servos for the swashplate controll)
the cyclic gyro would then controll the 2 axis in the hovering plane. the gyro would add/reduce thrust as necessary to keep the craft at a stable hover .... put another 2 HH gyros between the cyclic and the receiver , and you have a rock solid hold on the hover. ....
Well, the gyro is a good idea to start with. But the biggest problem is throttle lagging. All the helicopter use high speed servos to work with gyro. If the turbine throttle can respond in a split of the second. Maybe it might work.
Someday we get there. Just keep on imagine.
Brg,
Tam
