RE: The World models Extra 330L 60 Size
Well, I noticed that it will be hard to install the throttle linkage from the preinstalled servo position thats why I installed the throttle servo inside the cowling on the right wall of the fuel tank box on its outside. I used a mini servo hitec hs225mg but any standard servo will do the job as there is enough space. I cut 2 small squares of hardwood and epoxied them to this wall to use as servo mounts.
