Old 04-03-2006, 02:13 PM
Ernie Misner
Ernie Misner's Avatar
Default More Gorilla glue questions
If two planks are glued flush on top of each other, but the parts cannot be accessed to clamp them together, will there still be decent strength there? (the polyuethane glues expand when curing, so the two planks will not be perfectly together)
If just trying to add strength to the inside seams of an ARF, would running a little fillet of gorilla glue be adequate or similar in strength to adding a fillet of CA or epoxy to these joints?
When gluing wood to wood with gorilla glue, do most of you slightly moisten the parts first, or just "go for it"?
Thanks for you input or ideas,
Ernie
