RE: Antennae question
Joe,
Your planes RX has an antenna. Insects have antennae. Well, that is unless you have two receivers or an injured insect......ANYWAY. Doubling the antenna back on itself is just like cutting ti off wherever you make the 180* turn. You are better off bringing it down to the fuse and forward, or along the fuse, up the tail and then forward, or through the bottom of the fuse, forward and back through the top of the fuse and then back to the tail.....you could do it however you want. Just don't cut the wire or double it back on itself.
The likelihood of you flying far enough away to be out of range in either situation is pretty low, but better safe than um...hiking.
Later
