Old 04-09-2006, 06:00 AM
Bart[man]
Default RE: Remote Fuel Tank
Hi mduslic, My northstar kit is due to show up tomorrow, so I have been doing a lot of reading up on building tricks and tips for the northstar. I am using a OS .46 max and will be using a perry pump so I can install fuel tank directly over the CG in the fuse. Im going to use tail pod for throttle and elevator. I was reading something about making the nose longer to help in balancing as the northstar is tail heavy but havent seen any updates on this tip as of yeat. I hope this info helps. From what I have read, the things to worry about most is balanc exactualy to the specifyed location and build light. Good luck. Bart(man)
