RE: What The.... Noooooooo!
you make it sound like the only time the sensors work is if the two in front are pointed up. i still think from what i gather that it's only data. do you dispute that you wont get the same four readings if you have it upside down? 4 sensors 4 readings four of the same reading s to be interpretid by a smart software program. you are correct it is easier to hold the df up and keep your body heat away from it and the higher up you can hold it would provide better data for the TI program I'll admit i cant hold it as high when it upside down because of the switch location but i bet it would still work. maybe im giving the programmers more credit than is due but i have worked with some over the years and i dont think they would limit what the sensors are capable of capturing. enough of this DID ANYONE SEE ANYTHING WORTH BUYING AT THE BIG R?C SHOW OVER THE WEEKEND???
