RE: stryker-strait up.
The Stryker has two indentations in the handgrip, just above where your fingers would be holding. Try to balance at that indentation. If the aircraft tips forward, it's nose-heavy. If backwards, it's tail-heavy. You can adjust the center of gravity on a Stryker by moving your battery forward and backward. I apply Velcro tape to the battery and the inside of the battery compartment where I want my batteries to stay still.
There are other stops on the road to a perfect-flying Stryker, but that's the first station. If the CG is off (nose or tail), the Stryker flies horribly, as does almost any other plane.
