RE: Engine / Prop Vibration
Thanks all for the advice.
If you have an out of balance prop, how do you balance it. Sand it.
I cant imagine trying to glue small weights on it, or even just put glue on it, as they could fly off.
darock, when using your string and button method, are you checking it as it would be mounted on the plane (pulling both ends of the string horizontally, ---or by hanging it just from one end of the string (orientated as if it were a heli blade)
I think ill try a couple of new 11x6 APC props and see what happens.
Cheers
