ORIGINAL: JPMacG
I've seen guys with electric pumps drain a whole gallon into the grass thru the muffler.
With no models under 96", my tanks tend to be a bit on the large side, so I use an electric pump.
I use two DuBro fueling valves. One valve is installed normally in the line from the tank to the engine, for fuelling and defuelling. The second valve is installed in the tank vent line, and routes the vent line back to the jug when fuelling or defuelling.
I don't much care for throwing perfectly good fuel on the ground . . . asphalt and grass don't much care for it, either.
