ORIGINAL: mavtricks
Thanks you very much for the info lunchboxer. I just bought a lunchbox that has very little use off of ebay. I'm not sure if it will come with the brackets or not. If not, is there any way you could tell me what the part number is from tower? Thanks again!!
Shawn
Shawn,
You need 4 of these brackets:
http://www2.towerhobbies.com/cgi-bin...?&I=LXLDX0&P=Z
So you need to order 2 (as they come in pairs) Basically, you need 2 for the front upper mounts (lower mounts are there already, the same as the non-oil shock mount), and 2 for the rear upper mounts..
They came with the kit, BUT, they don't go onto the car if it still has the stock friction shocks, and since you are getting it used, it probably does not come with all the spare parts.. But like I said, in the worst case, $6 and you are good to go!!
Good luck!!
