Texan
Yes he does. He has 2 engines that are in that arena. A 46cc you can get with ei or magneto that puts out almost 30lbs of thrust. I have the new 42cc w/ei that will put out 25lbs of thrust and it is going on the GP GBS. It will hover that big red bird. Both engines weigh about the same(right at 4lbs w/ei). Scott says the 46cc is better pulling larger props at a lower rpm and the 42cc is better with a smaller prop at higher RPM. You can get eith the 42cc or 46cc from starting at $325.00 w/ei or you can get the 46cc with magneto for $240.00.
Give Scott or Mark a e-maill at
www.brillelli.com
