Old 04-17-2006, 03:08 PM
bobnreg
Default RE: covering turning yellow
Hi Guys . Just wanted to share with you a solution to removing urethane sealer from fabric covering on wing panel. I metioned I tried lacquer thinner--------- well yes it does remove the urethane .Here is what I did--- I used lacquer thinner but put it on with a pad of steel wool and rubbed until it became soft then using a towel rubbed until removed. A nice way to get out of a mess. Will now reclean surface with alcohol then reseal with clear sealer. Thought you would like to know. Bob D.
