Old 04-18-2006, 09:45 AM
Campy
Campy's Avatar
Default RE: covering turning yellow
Water base polyurethane is fuel RESISTANT, not fuel proof.
With water base poly you need to let it sit for a minimum of 7 days BEFORE exposing it to glow fuel.
Do not let the residue stay on the finish for more than 4 hours. After 4 hours the finish begins to soften.
As long as you follow the above caveats you will have no problems. I use the water base poly (Minwax Polycrylic) frequently and this is what I have found from experience.
Hope this helps.
