Old 04-20-2006, 12:38 PM
Campy
Campy's Avatar
Default RE: covering turning yellow
ORIGINAL: Deadeye
ORIGINAL: Campy
Water base polyurethane is fuel RESISTANT, not fuel proof.
With water base poly you need to let it sit for a minimum of 7 days BEFORE exposing it to glow fuel.
Do not let the residue stay on the finish for more than 4 hours. After 4 hours the finish begins to soften.
As long as you follow the above caveats you will have no problems. I use the water base poly (Minwax Polycrylic) frequently and this is what I have found from experience.
Hope this helps.
I'd sure like to know what I did wrong, then. I tried it once, let it sit for 2 weeks; the Polycrylic was gummed up and ruined after the first flight. It was exposed to the exhaust of 15% for less than 15 minutes. I'll never use it for fuelproofing again, but it is great for fiberglassing.
I don't know what happened. It is possible that you happened to get a bad can of it.
