RCU Forums - View Single Post - Fancy a FunFactor 6061 ARO chassis?
Old 05-03-2006, 09:26 PM
Dr Honda
Dr Honda's Avatar
Default RE: Fancy a FunFactor 6061 ARO chassis?
Hi all,
Well… here’s what I was thinking of. Basically the top plate will extend over the servo, with the servo wheel (the arm) coming out above the plate. Then it will tie into the chassis again via an aluminum block, and bolts running threw down to the chassis pan. (or servo block) What do you think? (it’s just an idea at this point) this will tire the rear and the front of the chassis as stiff, and compact as possible. The picture I got is of a stock FF… but Poor judgment’s picture looks like that may not work. Give me some input guys, so I can start to move forward with it.
