RE: DA50 Troubles - Help!
Send it back. I have 100% confidence in my DA's and fly low inverted harriers all the time. If you have no confidence in the engine flying the plane will be no fun. Right now you are just buying time until you crash it low and slow in a deadstick.
You should be able to just bolt the engine on and fly with confidence, no modifications or pressure plates/tubes should be needed.
