It could be that the 409 is partially reacting with the monokote adhesive. Try some clear windex and see if the same problem happens. also distilled water with a little bit of alcohol sprayed on will do the same job as windex without the ammonia.
Probably cheap vodka would work but we shouldn't go
there.
