RCU Forums - View Single Post - MVVS 49
Thread: MVVS 49
Old 05-09-2006 | 12:17 AM
DarZeelon's Avatar
DarZeelon
Default RE: MVVS 49
Rajeev,
Try connecting connecting a short silicone tube to the pressure nipple and blowing through it.
There should be a consistent - not intermittent airflow. Not massive.
The engine only uses less than 25 cc of fuel per minute and the nipple should pass enough air to replace the used fuel; much more isn't necessary.
The secondary needle may have to be closed - it is started at 1.2-2 mm from the throttle arm nut.
It will end up at less.
