RE: Mini LST
Wow there is alot of misinformation in this thread.
You can run 2 cobalts off the stock esc. Running 2 of the 14t motors will cause thermal shutdown so if you wanted to run the 14t's I'd suggest a better esc however it doesn't have to be a no limit esc. Any cheap 1/10 scale esc will do.
Let me tell you there isn't much difference between running one cobalt or two. That's why I run a single 14t cobalt. $40 bucks for the motor & on the track it would hang with any bl setup you could throw at it.
