RCU Forums - View Single Post - Tightening a differential with thick grease?
Old 05-21-2006 | 12:55 AM
nakamurak74
Default RE: Tightening a differential with thick grease?
Thanks JFACKY,
After several drift sessions, the auto grease started loosening up and I ran into the same problems. I went to the LHS and picked up 50,000 wt. diff lube. It works great. So far so good. I think as long as the lube doesn't leak out, it should be good for a while.
