RE: how do i prevent paint chiping????
Okay, make sure that the body is CLEAN before you paint. Make sure to scuff it up a bit with some scotchbrite pad/steel wool, to make it more abrasive. Also, make a lot of thin coats, instead of one big one. It also helps to heat the cans a bit in some warm water to make the paint spray morw evenly.
