RE: testing amp draw
Your Sperry meter may not have a high enough range current capacity to check your motor current directly. You would need a shunt. FMA Direct has such a device or you could simply get a Wattmeter that gives you current, voltage, amp hours, and watts all on the same screen. Hook it between your battery and ESC.
