ORIGINAL: digregoriod
Anyway in the case you want to test I would recommend you take the manufacturer's word for it.
It is a himax motor rated at 4-11 continuos with 14 amp burst. So would you say that the manufacturers are generally on target with their numbers?
I know that manufacturers always try to streeeeetch their numbers to make things look better so I was a little worried that if they say the motor needs 4-11 with 14 amp burst that it is more like 6-14 with 18 amp burst or something similar.
