You are talking about a funfactor?
THe clutch bell should come pff pretty easily once you remove the end screw. I guess if your bearing was whooped, it would make it a bit stiffer.
None of the clutch bells that I've ordered came with bearings. I dont know where you saw the bearing for 10$...
I am assuming that you are talking about the 2 5x8x2.5 bearings that sit right in the clutch bell.
They are $4.99 for 16 at
www.customrccars.com
http://www.customrccars.com/product_...at=22&custom=0
hope that helps
