RCU Forums - View Single Post - Click here if you're afraid of kits
Old 05-29-2006 | 07:52 PM
joesabido's Avatar
joesabido
Default RE: Click here if you're afraid of kits
Here are some more pictures:
Next we need to take the elevator halves and tape them to the hor. stab and mark the position for the joiner wire, which seems to be a piece of copper wire bent in a squared "U" shape.
[hr]
Next, we create a hole to fit the joiner in the spot marked in the plans, and now it's time to create a groove for the joiner wire, we can acomplish this by taking a 1/8 brass tube (the ones that come with du-bro tanks will do) and get them sharp using a hobby knife, and use it to create the groove by removing a little wood at a time.
[hr]
The groove should be deep enough to conceal the joiner wire almost completely, in a way so when you place the elevator and the hor. stab together you have about 1/16 gap max.
This is to ensure that the joiner wire won't get in the way when moving the elevators.
[hr]
Here go the vertical fin and the rudder
Ohhh and the ailerons too... this is going faster than expected... what a rush! [8D]
Stay tunned!
