Crystal for R114F explanation
Hi, I have a new Futaba flite pak on the way,unfortunately, the Crystal will be,showing up, 3 weeks later.[&o]Not sure why,there would be,such a big delay.Delema is;I`ll have a Brand new, "useless" flight pak,untill the crystal finally arrives.I know this receiver ,is supposed to use, a "Short" Crystal .Can I temporarily, use, the crystal, from my FP-R127DF reciever?I Know there`s an overall length issue,but will it plug into the R114F, and work ,aside from the crystal hanging out the side ,of the case a bit.The 2 recievers are on the same "LO" band.If this is not"do-able" would you mind to explain ,why not.I`m kind of curious/hopeful.... Thanks DAVE B.
