Old 06-03-2006, 09:47 AM
raston
Default RE: Homelite 45cc & Walbro HDB-6B
Hello BlackBaron,
I finally received my new carbs. It looks like I will have to do quite a bit of modificationto the carb mounting block to get them to fit on the Quadra's., ie: cut of carb positioning tabs on the CBM, trim one edge of the CBM off to accomodate a lip on the edge of the carb, enlarge the carb side of the intake port on the CBM to match the new much larger carb throat. Is this actually going to be worth all this? Or, is there an alternative mounting block I could use on this engine? (Perhaps you sell something through BCMA that would work...)
Any insights would be appreciated.
