RCU Forums - View Single Post - throttle push rod thru firewall to servo
Old 06-06-2006 | 10:25 AM
tuwood's Avatar
tuwood
Default RE: throttle push rod thru firewall to servo
ORIGINAL: BloomAce
Thanks Tony. A picture is worth a thousand words. I am assuming you haven't had any problems with this setup.
Mike
It worked perfectly & there was no slack at all in the throttle. I unfortunately lost the plane due to a power switch failure on the second flight, so I can't give you a long term analysis.
I will be doing the exact same thing on the next one I'm building though.
