RE: yokomo drift setup
Futaba Pistol Grip Controller
Batteries : 3000mah+ Nimh with Compatable Fast Charger with 12Volt Battery Connectors so You can Charge on location (Carpark Drift meets)
Motor Combo: Trinity Komodo 19 T Should do Nicely ( There are so many Possible Motor Combinations but a 27T-19 Turn is Best for Drift)
ESC : LRp 10 Turn ESC or a No limit ESC ( This allows you to run the 19Turns without too much Stress)
I am not to Fond of Yokomo as Its a little Expensive...
