RCU Forums - View Single Post - Model Tech Extra .25 questions.
Old 06-09-2006 | 08:54 PM
Sturtz's Avatar
Sturtz
My Feedback: (20)
Default RE: Model Tech Extra .25 questions.
Remove all that plastic off the plane , sheet and cover. You'll reduce the weight several ounces. The plastic is all hot glued on and will come off easy with a hot knife.
Mine has the OS.25FX w/3004 Futabas except the throttle which is a Futaba Hi-torque mini.
Flys a lot better after removing all the heavy plastic .
Had one with an OS .40 in it until the vibration shook the battery compartment loose which fell down on the aileron servo during a sharp turn. Just kept turning .
ID:	474950   Click image for larger version
ID:	474951   Click image for larger version
ID:	474952   Click image for larger version
ID:	474953   Click image for larger version
ID:	474954   Click image for larger version
ID:	474955   Click image for larger version
