Hinge Poll
All of my hingelines have to be sealed. So I like double monocote hinges or tape on both sides hinges (same as the monocote). On ARFs set up for CA hinges I've used crisscrossed strips of monocote with half of each hinge strip turned over to expose adhesive (boy that doesn't make much sense, but you probably know what I mean).
What is the recommended way to use CA hinges or point hinges, primarily in regard to hinge sealing. From everything I've ever read hinge sealing is extremely important. So what's the best way to seal a CA hinged line?
Balin
