RCU Forums - View Single Post - monocoat as a hinge
Old 01-03-2003 | 04:49 PM
big max 1935
My Feedback: (9)
Default monocoat as a hinge
You can use the old U/control hinge of pinked fabric ( over & under type)with Sigment or Ambroid. You can sew them, carpet thread or newer materials.Use two strips iron on fabric ( one of the tex`s) cut them 1" wide & 12" or so long , put the glued sides together & use sewing machine(remove backing first) cut to length you need. Then slip surface in slot on each side & iron on. Or you can go with the plastic covering as they say (plenty strong). All these work good on thin surfaces, I always liked the old model air plane glue,so much fun to chew it off your fingers !!!Hope this helps.>>>>>>>>>big max 1935
