RCU Forums - View Single Post - IS this Acceptable???
Old 06-18-2006 | 09:06 PM
ElToroLoco.'s Avatar
ElToroLoco.
Default RE: IS this Acceptable???
sounds good to me.. you probable want to get an aluminum driveshaft and some bearings along with some other basic upgrades though, since it is a pretty basic car. It is also good to get a motor with a high torque, so if the 12 turn doesn't seem to work good, switch to a 19 turn. You also will need to make tyres from pvc pipe, abs, or get the yokomo drift rings. The tires are one of the most important parts.
