Okay, I'll start looking for the 2820/10 instead. That is certainly one part of the electric world that still eludes me - wound around 10 turns, 12 turns, etc. In my 'glow infested' mind I thought more turns would be a better thing. I have thought that someday I might try a 4S pack and would need the 12 turn version to do that, but if the plane flies well on a 3S, I'll probably never use anything else. 31 static amps is very interesting, higher than I expected, but I certainly trust your data and I will go with at least a CC35, but will probably get the CC45 in case I want to use it for other applications some day. I'm sure you are already familiar with this site, but I was getting the data I had from
http://www.flyingmodels.org which has a huge list of data regarding AXI motors using various props. Again, I really appreciate your help in starting with the correct equipment.
