Question Re Engine Mounting to Sig 4*60
I used a flexable throttle wire that came as a kit with the guide tube. This worked very well and was much easier to work with than a solid rod sonce I had to go up so high. These throttle cables should be available at your LHS. Here is my setup using an O.S. 91 SII w/pump
