RCU Forums - View Single Post - Showtime for Pattern flying?
Old 07-03-2006 | 06:58 PM
  #59
fastplane
Default RE: Showtime for Pattern flying?
Advent, I am considering the ST for a next plane. How is the plane working out?
I want a pattern flying type plane and also IMAC. 3D ok but already have a Funtana 40 size.
I am interested in your setup. I have a NIB OS 120 Surpass III w/pump. Is this what you are using?
The OS 120 w/pump has more stuff on the back and I question if it has room to fit in the fuselage?
I have 4 Hitec 645 metal gear servos.
Most likely put servos in tail if available.
Do you use the pull-pull cable?
