RE: Brisk Spark plug alternative for MVVS/Evolution?
BPMR6F is a projected tip plug - stays cleaner. It works fine in the ZDZ as a replacement for the Brisk UR17 which is not a projected tip plug. Both are tapered seat. The MVVS likely has enough plug clearance to run the projected tip also.
