RE: mixer offset for 8103..........
Go to a program mix, such as mix 3. In the mix (after you have selected the master and slave channels, which could be as simple as pressing the + key to turn the mix on) you will see 2 percentages to the right of where it says Rate:, one is the "high" value that I am speaking of, and the other is the "low". It would be best to open a clear model and set up a mix and experiment to learn. Also feel free to contact our product support department at 877-504-0233 for assistance also.
