I still have mine, previouslyTee Dee .020 powered with Ace Pulse Commander Single Channel. The GWS EPS 100C (280) 2.8:1 and an 8 cell 300mah NiMh pack and 8X6 GWS prop with submicro R/C stuff should work. An GWS IPS with 8X6 prop or Direct Drive motor/prop should also work. Plane will fly fairly fast. Might want to add a coupla bays to the wing and beef up the dihedral break areas a little.
