ORIGINAL: thundir3
Hey badz, I do own a Jato and it is not the toughest truck I have ever had. The main problem I see is that the car does not have enough braking power for the large motor and 2 speed, but what can you do on a 2wd. And the rear tower is weak even if the springs are adjusted correctly so just have an extra, because for me it was a PITA to find. I also heard that if you upgrade the chassis then the upper tray and servos dont break as easy.
What chassis upgrade? I have not seen anything about traxxas upgrading the chassis on the Jato.
And as far as the braking goes, I can stop mine from WOT to deadstop in less than 30 feet without spinning or flipping it.
Seems to me that the brakes work just fine.
