RE: WALKERA 37
Looks Great Mike! It's interesting to see how you hooked yours up. My ESC is on the other side and I connect the battery on the other side as well. I'm glad to see you have that zip tie to hold the battery tray from snapping off during a hard landing. I used some wire to make a permanent holder. I use velcro on my battery and battery tray to hold the battery on. It also keeps it from moving towards the motor housing. I'll try to post some pics at some point.
Did you use the 11T? I was thinking of going back to 10T since I didn't see too much of a difference and my 10C battery stays cooler. There is such a big difference between my 10C battery and 12C battery in terms of temp. The 12C stays just "warm" during use, while the 10C seems to get hot. I can only run the 10C for 6 or 7 minutes before having to let it cool down. This was not the case with the 10T I had been running. The ESC and motor stay about the same temp with either pinion.
SORRY, I MEANT "JIM!"
