RCU Forums - View Single Post - How do you store your planes ????
Old 01-17-2003 | 06:43 PM
  #37
smthlndr
Default How do you store your planes ????
I STORE MY PLANES HANGING BY THE CEILING IN MY HOBBY ROOM. I USE FINE 50LB. FISHING LINE AND COLORED HOOKS IN THE CIELING. I USE FOAM RUBBER TO GO BETWEEN THE LINE AND THE REAR OF THE FUESLAGE BY THE ELEVATOR SURFACE. AND THEN I HANG THE FRONT BY THE ENGINE JUST BEHIND THE PROP. YOU CAN WALK IN THE ROOM AND THEY LOOK AS IF THEY WERE IN MID AIR BECAUSE YOU CAN'T SEE THE LINE. YOU CAN ALSO ADJUST THEM DIFFERENTLY WHEN YOU GET TIRED OF THEM HANGING THE SAME WAY. I HAVE HAD THEM THIS WAY WHEN NOT FLYING FOR 4 YEARS NOW AND ALL SEEMS TO BE FINE. NO PROBLEMS ANYWHERE.
PLANES BELONG IN THE AIR EVEN WHEN YOUR NOT THERE!!
