RE: Marez on Parallel Operation - One more time.
Red:
I also read this in High Flight and said to myself "here we go again".
You convinced me several years ago and I have had nothing but complete success running parallel batteries through two switches.
The only problem, and it is documented as a problem, is trying to charge both batteries using a "dual output" battery charger.
It is not the fault of the battery configuration. It is a problem with the design of the charger.
How long will it take you to convince Good ol' Eloy?
