RCU Forums - View Single Post - Conversion of a Pattern/ Artistic Aerobat
Old 07-20-2006 | 04:34 PM
ExFokkerFlyer
Default RE: Conversion of a Pattern/ Artistic Aerobat
Careful Mike, watt readings alone on this forum without RPM will likely start an argument. Well at least that is what happens when I do it. [8D]
Conversion looks real nice, would like to see something like that available on the market. As far as weight goes, not sure about balance, but under 11 lbs would be a piece of cake with a lighter mount and batteries. But if that's what you have on hand, hey, what's the difference it's all good equipment!
For pattern type performance, not 3D mind you, and AXI 5330 would be a couple ounces lighter, and a 5320 would be about 6 ounces. Not sure about the mount but some could be lost there, and 5-6 ounces could be had with the Flight Power 3700s.
How is the Hacker motor running for you?
