ORIGINAL: mikehuff
Front left dogbone keeps coming out on my MT2, took everything apart on it, can't figure it out, screw on the knuckle is stripped but it doesn't make that big of a diff, the dogbone is loose, any suggestions???
if the screw on the knuckle is stripped then YES, it does make a difference. convert to CVD's instead of dogbones, and replace any worn out parts, including stub axles and diff outdrives.
