RCU Forums - View Single Post - Looking for David Gladwin
Old 01-02-2003 | 04:13 AM
David Gladwin's Avatar
David Gladwin
Default Looking for David Gladwin
Les, I do not use the kit pivots. I use the steel shaft and brass bearings from Air Magic. (the shafts are captured by plywood boxes in the stabs.) So far even with the JetCat 160 absolutely no problems.. I glued in some extra ply stiffening to support the bearings. Do not compromise in this are if you are using a powerful engine.
BRG, David Gladwin
