RE: ModelTech Cap 21
Congratulations on getting past the nonexistent instructions.
I would be a little concerned about using CA hinges on the ailerons, since the wing is balsa-covered foam. CA will normally dissolve foam rather than creating a nice strong joint. I used plastic hinges on mine glued in place with epoxy.
