ORIGINAL: soneebee
what align tail blades ? are those the longer CF ones? or the plastic ones that are a little longer that the original.. how does it perform.. an using the 61mm align tail blades on my heli and it seem to hit the ground..
Hi Soneebee, they are the stock plastic ones. They are slightly longer and have a different shape. They work fantastic. The only problem was that I had to use my dremel and grind a small bit of plastic from around the screw hole. They were too tight in the stock DF37 blade grips and did not move very well, even when the screw was loose.
