RCU Forums - View Single Post - Nitroplanes.com
Old 08-02-2006 | 12:10 AM
  #45
superman65355
Default RE: Nitroplanes.com
My point exactly, I was not aware that is was originally marketed as a .30 size plane that will make a world of difference now overpowering model can be done but it DOES have its limitations. And I strongly recommend that if you are going to over power a model do so only after you have reinforced the firewall
OPJOSE is right if ya pull the firewall out don't get mad at the model. Tis like putting a 454 in a gremlin, it may go like a bat out of **** but it will more than likely have an unhappy ending! Thanks for the info I did not know it was originally a 30 size plane!
