RE: Pipe/manifold length on the West Eurotech 50 V1
1/4" that is about 6mm...
Well that was what I expected but I just want to hear if there was someone else with the West Eurotech 50 V1 who had the same problem that I have. If you read the instructions - no cut off will be needed if you use a 8x10 propeller.
The engine will not blow plugs until the pipe is too short, doesn´t it?
That were nice planes you got but I would had a rear exhaust engine on the dust with a tuned pipe if it were mine!
Anyway, good luck with the premiere flight.
/Eric P
